WhoMe08721
123
Bayville/NJ
It's a custom clean diesel fuel tank I made for my arctic heater. I don't use the main fuel tank to feed the heater because at the beginning of this summer I started to run 90% used motor oil and the truck love it. The rpm went don't and just over all it running better. The only problem I have is when you turn the main switch on you have to wait a min before hitting the start button to let the thick oil fuel make it up to the motor.
Nomad1
Conway NH
Good information I'mgoing to start looking into more stuff about the different heating system for the deuce.I have the heater core type right now and haven't got it completly operational. I plan on running the truck in the winter
rustystud
3,257
Woodinville, Washington
Yes, Rusty, I hope you can photo the two different guages you refer too, as I might want to implement your idea on my rig too. REmember what General patton said: You can tell a mans worth by the wrecker he drives..
Hey "whatadeuce" did you see my pictures of my dash you asked for ? You never responded. I was wondering if that was that what you where looking for ?
jeffhuey1n
SMSgt, USAF (Ret.)
1,590
Laramie County, Wyoming
I’m also looking for bits and pieces of the hot water heater. I’ve got a complete set of parts set in excellent condition. Now to get them installed...
Mrmag1
Head of Stuff N' Things
14
Hereford Arizona
Well I'm starting to load up for the move, the jib crane all be it Scarry that it was gonna drop my 800lb safe, worked great. Everything else is cake to load from here.
Nomad1
Conway NH
Mines in the truck just need to get the duct and pieces that go from the fan to the side pannel and punch the knockout. 1st I need to get temp gauge working to see when the engine is up to temp and make sure it's flowing threw the heater core.
whatadeuce
Loxahatchee, Florida
Hello brake conscious troopers, and for my M35A@, here is a question for a Sunday: The assumption is that the hyd stop lamp sw, as shown in the diagram, is the brake switch bringing voltage to the rear brake lights. My question is, where is this switch physically? Thank you
Merc1973
Sykesville, MD
Power washed theold girl. Its been 5 years. Lichens have started growing.
I need to replace some shreaded generator belts that were barking at me last trip picking up a frew firewood we just cut.
