kcpstudio
- 6
- 8
- Fleetwood, PA
Greetings members,
First, I like to apologize for the long delay in getting this video completed. Because of the file size, I placed it on Youtube. I filmed the video in 4K to make sure you can see any important detail you may need to assist with the mods. This is a 60,000 BTU heating system which, at medium heat, gives you around 119 degrees F in the front cabin area and around 98 degrees F in the back area behind the rear seats. This is more than enough heat to take the chill away.... sepecially for you gents living in colder climates.
Originally, I was going to produce a kit to include an enclosure but have since decided to just upload the information and let this be a DIY project for you all. There are a couple things I designed and manufactured here in my shop, and I'm happy to make those parts for those that don't want to tackle them.
It is extremely important to note that you do a full inspection of your cooling system and repair or replace any items critical to the existing heating system because that will have a huge impact on the performance of this mod. If your current heater core is old, clogged, etc etc.... replace it. You can then make the mods to the new core before re-installing. If you radiator is in poor shape.... fix it. Make sure to flush any old coolant and start with new fresh preoperly mixed coolant. Period! HMMWV's heating system is a poor design to begin with without adding more issues into the mix. We will be keeping the factore heating system in place and that will be used only for windshield defrosting.
1. The main unit is a: SPAL Type 006-B46-22 24V 60,000 BTU Heating unit (you can find these on Ebay from time to time).
2. The next item you will need are 2 Bypass hoses from NAPA Auto Parts. The part number is 9812. They are approx 36" long with a 90 degree bend at one end.
3. Next you will need 2 Goodyear 5/8" E-Z Coils. The part number is GY58UBP. You can find these at Pep Boys.
4. Another item you will need are 2 90 degree heater Hose Elbows. They are made by "Dorman Help" and the part number is 47062.
5. You will also need is a 4 gang switch box offered by "federal-military-parts" 612-440-8877. You only need the box. No switches.
6. Next, you will need an assortment of HMMWV electrical connectors and wire. This is a 24 volt system! Do not use crap! You have been warned. You can get the parts needed to complet this through Erik's Military and Industrial Surplus. 760-520-1523. NOTE: you will need a special tool to crimp the connectors. Again... 24 volts... do not use crap! I will offer the mini wiring harness to members if you do not feel comfortable making your own.
7. You will need hose clamps. I use factory crimp clamps on some of the truck and screw type to make repairs on the road easy. Keep in mind very few auto shops would even know where to begin to work on these vehicles. Keep a care package in your truck at all times... especially if you do long road trips like i do.... 1,400 round trips.
8. You will need duct hosing. I used Blo-R-Vac Flexible Duct Hosing from McMaster-Carr. The part number is 53145K28. Keep in mind this is for 1 3/4" outlets found on the SPAL unit I have. Your outlet diameter may differ.This is the best replacement hose for your HMMWV. It will not rot and break down like the factory crap. I replaced all my hoses with this or similar in various diameters.
9. Next up is High Temp Expanding Sleeving for your wiring. I use it throughout my truck to protrect my wiring. It's a factor sleeving. It 1/4 ID with a 1/2" ID expanded. The part number is: 2656K11.
10. The two main custom parts I made were a front machined aluminum cover for the switch box and a insulated wrap for the two heater hoses. Again, I will offer these up to the members if they want.
11. You will need a Heater Fan Switch. You can get this from the Hummer Parts Guy. His phone 920-216-6898. The part number is: 00-226-6429.
12. Next you will need a Heater Data Plate. This is the sticker associated with your existing heater/fan controls. Again, you can get these from the Hummer Parts Guy.
This is pretty much the main parts you will need. Please grab a cup of coffee and watch the entire video. I tried to keep moving and not bore you to death. Besides... I took the time to do this listing and shoot the video and wait God aweful long for Youtube to upload it..... it's the least you can do. ha ha But, seriously... if you guys have any questions, please don't hesitate to hit me up.
Enjoy the video. https://youtu.be/FhrYGG8V8yA
Cheers,
Ken
Cheers,
Ken
