alexv707
- 0
- 1
- vacaville,CA
I’m at a loss. I had no output from the 60 amp generator so I decided to swap it out with the 160 amp alternator kit. I also installed the ground wire kit, 2 new batteries and battery on off switch. Everything works but I still have no output from alternator. I get the same voltage at rear of alternator as I do at batteries with engine on or off. Alternator is 1 wire style. Wait to start light functions as it should and so does everything else in it. Does anyone know where the charge wire from alternator + terminal go to? I assume it’s not broken since I have power to it. Has anyone bypassed the factory charge wire from alternator direct to battery
Thanks for any suggestions you might have or areas to check.
