HMMWV Fuel Lift Pump
BradIXXI
Dallas, Texas
Does anyone know the O'Reilly's or Auto Zone part number for a '04 HMMWV M1097A2 6.5L non-turbo mechanical fuel lift pump (see below):
They are telling me that on the ones they sell it does not have the vent nipple (shown in Yellow above.
Any help would be great....
BradIXXI
Dallas, Texas
This is the one I just installed from AutoZone. It’s the correct ac Delco.
Do they sell one for North America that is right side up? I assume you are Down Under sense your picture appears upside down to me?
Thank you soooo much for the info and so quick.....
papakb
1,194
San Jose, Ca
I just did this job on a friends HMMWV and there's no good way to push the fuel pump actuator pin back up into the block without removing the mounting plate. The gaskets are readily available and fit 1955 thru 1995 GM engines and only cost a few bucks so bite the bullet and remove the plate. I used wheel bearing grease to hold the pin up in the block when I remounted the plate and it washes out after the engine warms up so it won't cause any problems down the line. Use a touch of Permatex Hi-Tack to hold the gaskets in place. A word of advice when you do this job, remove the right splash panel and have a long extension with either a 3/8 swivel socket or a universal with a 3/8 socket to put things back together. This allows you to tighten everything up reaching in over the frame rather than busting your knuckles on all the solid stuff in the neighborhood.
Gasket mounting plate to block: FEL-PRO 5182
Fuel pump: Spectra Premium SP1143MP
Pushrod: Carter PR4
jaredsalinsky
tampa, FL
Hey all. My fuel pump is leaking so I’m gonna replace it. Thanks above for the part number. But how in the heck did you get it done. There’s no dang room. I mean the bottom 2 bolts holding the plate on are barely get-to-able. But the top 2 - man there’s no way. I tried coming in from the side but it’s pretty tight. is there some special order of operations, or something else to remove first? (Btw I do have the FSM but before peering into that million page encyclopedia I thought I’d check the forums first!)
Any help would be much appreciated
thanks in advance.
papakb
1,194
San Jose, Ca
  • Like
Reactions: OBX
Mogman
10,167
Papalote, TX
Pushrod: Carter PR4 or Dorman 03875
Are you sure about that Dorman part number? the Carter number looks good but not the Dorman.
  • Like
Reactions: OBX
jaredsalinsky
tampa, FL
Thanks. Understood
do all 4 bolts hold both the pump and the plate to the block? Or do the top 2 hold the pump and the bottom 2 hold the plate? I’ve read some blurbs from people about removing the pump but not the plate (and the the pushrod gets stuck); I can’t see why you wouldn’t just remove both while you’re right there…
papakb
1,194
San Jose, Ca
From the drawing you can see that the upper two bolts (1) hold the fuel pump in place and the lower two (11) attach the plate to the block.
I got the Carter rod pn# by cross referencing the AMG pn# 14050425 on the internet. It crosses to the Carter SP4 with .449 x 5.29" dimensions. Also via internet search I got the Dorman number of 03875 but checking it's dimensions it's showing .500 x 5.75" which is too long.
Sorry for the bad info! Stick with the Carter part.
Because of the angles and limited work area I think it's easier to remove the plate when doing this job.
  • Like
Reactions: OBX
Maxjeep1
1,927
Las Vegas Nevada
Plate has to come off. You need to have no more than 1/2” of rod sticking out of the block. I ordered my pump and gasket from HPG. There is a difference in both. I put grease on my rod lol and put it in the freezer overnight and that gave me plenty of work time for my limited abilities. I have replaced fuel pump on my M1123 and my M1165.
  • Like
Reactions: OBX
Mogman
10,167
Papalote, TX
When you put it back together, use a little sealer on the plate gasket and thread the pump bolts in a little ways before tightening the smaller plate bolts, this will insure that the plate is lined up when you install the pump. Otherwise you could find it difficult to start the pump bolts.
Do not use something like 1 minute gasket maker, just plain old silicone sealer or it could set up too fast.
williamh
676
SanDiego Ca.
First thing I had to replace When I got my truck. I just used heavy wheel bearing grease to hold the pin. I would recommend not re connecting the vent line to the system and just put a short hose to drain in case it starts to leak again. the next thing you should do is pull off your wheels and check the hubs to see if the diesel has found it’s way threw the vent system into the hubs thining out the oil , it wouldn’t take long to destroy the hubs.
Jake0360
15
Dade City Florida
Thoughts about getting a higher GPH fuel delivery system to increase the Governor limit on the 6.2L.
Does the 6.5L and the 6.5L-T have a higher GPH FP for larger displacement and Turbo engine? Or is this just a bad idea?
Mogman
10,167
Papalote, TX
Anything over around 15PSI starts to affect the timing, it has nothing to do with the amount of fuel delivered.
All 6.2/6.5L IPs can be turned up to far over deliver fuel so you do not need to change pumps (or IPs) to really screw things up.
Mogman
10,167
Papalote, TX
But to answer your question farther the 6.5l NA and Turbo IPs have larger plungers than the 6.2L, but again the 6.2L IP can be turned up to over deliver fuel to ether or all 6.2/6.5L engines
