BradIXXI
- 3
- 3
- Dallas, Texas
Do they sell one for North America that is right side up? I assume you are Down Under sense your picture appears upside down to me?
This is the one I just installed from AutoZone. It’s the correct ac Delco.
That is the Australian model. It is upside down. He needs an American one.
Are you sure about that Dorman part number? the Carter number looks good but not the Dorman.I just did this job on a friends HMMWV and there's no good way to push the fuel pump actuator pin back up into the block without removing the mounting plate. The gaskets are readily available and fit 1955 thru 1995 GM engines and only cost a few bucks so bite the bullet and remove the plate. I used wheel bearing grease to hold the pin up in the block when I remounted the plate and it washes out after the engine warms up so it won't cause any problems down the line. Use a touch of Permatex Hi-Tack to hold the gaskets in place. A word of advice when you do this job, remove the right splash panel and have a long extension with either a 3/8 swivel socket or a universal with a 3/8 socket to put things back together. This allows you to tighten everything up reaching in over the frame rather than busting your knuckles on all the solid stuff in the neighborhood.
Gasket mounting plate to block: FEL-PRO 5182
Fuel pump: Spectra Premium SP1143MP
Pushrod: Carter PR4 or Dorman 03875
Anything over around 15PSI starts to affect the timing, it has nothing to do with the amount of fuel delivered.Thoughts about getting a higher GPH fuel delivery system to increase the Governor limit on the 6.2L.
Does the 6.5L and the 6.5L-T have a higher GPH FP for larger displacement and Turbo engine? Or is this just a bad idea?
