acudanut
- 38
- 18
- Gardner, Ks
The Perkins is a 454 Cubic Inch straight Six.I will have to check. Yes, it's a straight massive six. Engine weighs over 1500 lbs.
I didn't know Perkins made a 6 cylinder 454. You sure it's not a 354.The Perkins is a 454 Cubic Inch straight Six.
If its a 354 you won't be happy with its performance in the 1009 unless you plan on only using it off road . It has less torque and horsepower than the 6.2. Also it red lines at a much lower rpm so that will limit your top speed.I didn't know Perkins made a 6 cylinder 454. You sure it's not a 354.
Added 2 more springs on each side up front. Added a 3 inch lift to clear the motor.Will do. I realize that some do not care for the Perkins engine swap. All I can say is..My truck, my way. !!
