MTVR
- 742
- 93
- Waco Texas
I've read most of their book (about 400 pages) as well as countless tutorials, spec sheets, videos, MSDS pages, and so on...I used the West System to make and seal a hot tub. Amazingly strong. The Gougeon Brothers (they make the West System) are good people : )
3.5" thick rigid polyiso foam boards, with that "Great Stuff" foamed into any crevices.What type of insulation do you plan on using?
If you look underneath the platform on the driver's side, you will see that the leading edge is not supported as well as the trailing edge. We did add some stiffness to the trailing edge, but we have not done anything about the leading edge yet.Looking incredible! Also I noticed that platform on driver side is a little flimsy when stepped on and looks like you will stiffen it up with the frame you added to the outside edges. Nice.
Also, will the scissor stairs fold up and secure in that position if desired? You are doing some great work there....
I'd recommend getting the pro gun. Depot has them with the cans that thread on. Allows to keep the product good even if you don't use the entire contents.3.5" thick rigid polyiso foam boards, with that "Great Stuff" foamed into any crevices.
Thanks.I'd recommend getting the pro gun. Depot has them with the cans that thread on. Allows to keep the product good even if you don't use the entire contents.
Better control depending on what you need for the void.
Use door and window foam for small voids. Less exspansion/ pressure on critical framing/ components.
The Gun cleaner isn't really necessary if you swap the can when it's empty and run a Lil of the new can into it.
