Steelreaper80
- 96
- 28
- Indianapolis IN
I did an oil change today and my semi sized oil filter wrench ever so slightly cut through the insulation on the wires underneath the oil filter causing a spark storm. I taped up the cut in the insulation with electrical tape and went on to deal with a spring brake bladder replacement and wheel bearing inspection on the passenger side center axle. Hours later I went back to start the truck to make sure I did not have any oil or air leaks and no power at all to the truck. No lights either. What did I fry? I just ran the truck two day ago so I know the batteries are charged up. Any help is appreciated.
