f3504x4
- 15
- 8
- crescent city ca.
We recently purchased a m109a3 located in philly and we reside in nor cal. Our question is, how many miles can one expect out of 900x20 ndt ties?
?On the front, from philly to nor cal.
Not sure how many days. I take it 900x20 tires wont last long? And i do not know 4 digit number on any of the tires. It will be an adventure im sure. Will a bottle jack raise unit enough for tire r&r? Thank you for taking the tome to respond.Put new tires on the front steer axles and use the takeoffs as spares.
Get your tools ready. Is this like a 16 day drive?
Thank you for the information. Where can someone purchase new 900x20 ndt tires?It depends on their age and condition. The casing may fly apart in a few hundred miles.
Original new NDTS would be around 20k depending on the load
There isn't that is reasonableThank you for the information. Where can someone purchase new 900x20 ndt tires?
Thank you in advance.
They will be worn out on the front axle after travelling 3000 miles from Philadelphia, PA to Crescent City, CA.
Thank you, will the1100x20 tires rub on the drivers due to larger circumference?There isn't that is reasonable
If you want to swap tires go to g177s in 1100r20. Will increase your road speed and they wear like iron. Takes alot to wear em down
11.00R20 GOODYEAR G177 LIGHTLY USED 80 - 95% TREAD | eBay
Freight is from Norfolk, VA. Whether or not there is a forklift for unloading.www.ebay.com
That is good news!
G177s dualled on the back of a deuce will rub slightly on a trunnion cap bolt head.That is good news!
Very good to know , thank you once again.G177s dualled on the back of a deuce will rub slightly on a trunnion cap bolt head.
My opinion, not that you asked for it- run with what you have . You have plenty of spares. Change out to 395's on mrap rims with spacers at some point in the future.Very good to know , thank you once again.
