Allison 1545 Automatic Transmission Specs
HDN
5,341
Finger Lakes Region, NY
I saw this posted in the 1545 failure poll and was surprised to see it wasn't repeated here:
Not exactly the thread for this, but I'm trying to (discretely) spam this info I just found about AT 1545s:
For those 1545s with serial #s GREATER than 321-101-6535 (or retrans GREATER than 9108-0912-20), there is a newer option for the front pump. This newer option involves replacing the front pump and stator. It retains the lockup. Darpco in Dallas (likely among others) can assist with this.
Good luck!
SJ
HDN
5,341
I have a 545 and I have changed the transmission fluid and filters ... it seems to be doing fine except if I don't hold the peddle to the floor when speeding up the transmission jerks when going from 3rd to 4th ....any ideas about what could be going on ?
It is my understanding that this is normal behavior for the 545 transmission. My truck and another owner's do the same thing. It just clunks into 4th gear, and the tranny takes its time shifting into third. I almost thought it was going into another gear between where it felt second and third were!
FWIW my experience has only been with the motor oil it came with. I plan on switching to ATF in the spring.
rustystud
3,257
Woodinville, Washington
To much "governor" pressure. Your using "modulator" pressure to counter-act the high "governor" pressure when you hold the pedal to the floor.
The governor weights could be sticking. Take it apart and clean it real good.
HDN
5,341
I'll have to get this checked out now. Although my jerk may be different from the other guy's jerk. Probably best for me to get it checked out at the local Allison shop and have them do the ATF conversion as well!
URSATDX
20
So Jersey, NJ
I am planning on doing the MO to ATF conversion on my Allison 1545. I will introduce the ATF thru the check/fill tube. In order to insure a complete and thorough flush what would be the best point to disconnect the flow circuit so that the entire trans and cooling system are flushed. I’m assuming the ideal disconnect would be at the return line at the transmission. Thoughts? If this seems to be the best location, I would need to confirm the direction of flow of the MO/ATF in the system. I am ASSuming that the fluid flows from the trans to the top of the radiator out the lower radiator to the trans cooler (top) and from the cooler back to trans. If this is the correct direction of flow then I will proceed to flush until the fluid at the trans return line is all ATF and no MO. I’d then drop the pan, replace filter and gasket. Replace the inline spin on filter, run and adjust fluid level.
Suggestions on ATF types?
Any thoughts from the troops?
Much appreciated.
God Bless our Great Country!
rustystud
3,257
Much appreciated.
The return line is located directly behind the breather vent. This is the procedure we used at the transit agency to flush the bus transmissions. Just be careful ! Don't allow the transmission to run dry ! That would destroy your oil pump in a heart beat !
Since I'm pretty sure you don't have ATF on a pressure system like the transit department does, (we just put the nozzle in the transmission fill tube and pulled the trigger and out poured ATF at 20 gallons a minute) you need to run the engine in short bursts. Then top off the transmission and run it again. Do this until the fluid runs clear ATF.
URSATDX
20
So Jersey, NJ
Thanks for the response, Rusty.
Looked thru TMs for answers, but I have a hard time navigating thru them.
I do have an ATF dispenser (gun) fed from a 110 gal tank. (Own/operate a quick lube).
The tank is filled with a multi veh full syn ATF. (Specd for Allison / Allison (C-4 / TES-295 / TES-389) . I will look for a diagram of the 1545 to be sure I pull the correct line. I'll keep you posted on the results.
Thanks again.
God Bless America.
Sgt Jiggins
Potato Peeler
270
NorCal
I'd like to make one more add to this thread: after having my 1545 rebuilt the rebuilder suggested using "John Deere Hy-Gard Transmission and Hydraulic Fluid" (not just Hy-Gard Hydraulic Fluid - there apparently is a difference?) in it. I know fluids in these things come up in discussion frequently and don't want to start a battle with this information but maybe put it out there as an alternative in case people are still not happy with other options.
As always, YMMV har har
Boatt2082
Jacksonville FL
As someone who just purchased an M36A3 I found this thread very helpful.
Has no one found a alternative transmission for the A3 (maybe one with an overdrive)
Toby what’s the big difference in a locking converter vs non locking ? I see you say a non locking isn’t preferred for a highway vehicle. Any way to elaborate a little more on this?
I’m not a transmission guy by any stretch of the means.
Thanks in advance
HDN
5,341
Thanks in advance
Welcome! And you have a pretty rare truck in an M36A3! I think you should start another topic and post pics :cool:
The locking transmissions eliminate losses between the engine and transmission through the fluid coupling (torque converter) in 3rd and 4th gear, increasing fuel efficiency. In function, it's like a clutch in a manual transmission.
As a result of the locking feature, it seems it puts extra stress on transmission components responsible for 4th and reverse gears, causing eventual failure of those components (but maybe this only affects trucks that are regularly loaded with heavy cargo?).
The Army seemed to have realized that this was a problem because they have instructions in one of the support TMs for switching a 1545 with the more-common non-locking 545. The 545 has been used in trucks and school buses for years, so I wonder how much less fuel efficient the A3 would be on-road. The Army didn't think it was a big deal, evidently.
I'd prefer to keep the 1545 on my truck and try to fix it if it broke. From reading around here, the stressed components can be replaced with those found in other flavors of Allison - maybe it's a HMMWV transmission I'm thinking of?
Plus the private bus owners like the 1545 for the torque converter. It seems quite a few of those bought the surplus 1545s when they were still around!
I don't think there are any OD automatics that would fit in the space available under the truck without shifting a lot of stuff around. I think the ESP avoided that to keep costs low.
tobyS
839
IN
The A3 is a redesign of the A2 and A1, but eliminate shifting. By the wisdom of the day, they took a good performing commercial Allison 545 and added the feature of the locking TC, calling it the 1545.
Probably the reason there is a different thunk between 3rd and 3-4, is that the 2-3 shift is unlocked while the 3-4 shift is with the converter locked and does not soften the change so much.
Seems someone should make it only go to locked after going in 4 to reduce the 4th gear stress on the gears and fourth clutchs...which is the weak link.
If you missed it before, look up the "direct" clutch in the L480E and consider the race frictions, steels, and vulcanized steel piston to replace the OEM clutches and aluminum piston.
HDN
5,341
The transmission is supposed to unlock between 3rd and 4th gear. And thank you for the 4L80E mention. That's a pretty common transmission outside HMMWV applications, I think, so it shouldn't be hard to get those parts!
46
17
Chester , VA
just want to say thank y'all for sharing your knowledge to people like me ...who have sometimes think they know it all and then wake up and know God is the only one that knows it all ...
tobyS
839
IN
No, go back in this thread and it gives the shift sequence. Going from 2 to 3 the converter is unlocked. Then the converter locks while in 3 and is locked when going from 3 to 4. That puts a lot of strain on the 4th clutch pack that could be avoided.
The parts I reference are high performance, not just the standard OEM. They are thinner so have a couple more, tougher material and the vulcanized steel piston holds more pressure.
It would be nice if there was an easy change on the shift pattern or making the lock-up entirely manual. I'll ask my Allison man.
  • Like
Reactions: HDN
tobyS
839
IN
It would be nice to have the details of the 1545 lock up torque converter control. Does anyone know how the hydraulic pressure is controlled inside of the valve body? I think most Allisons now use electronics, but the 1545 is hydraulic..... Hey Rusty???
HDN
5,341
Okay, guys, if anybody is still checking this thread, I found some info (maybe outdated) on these 1545 trannies.
Gear ratios: 3.45, 2.25, 1.41, 1.00 to 1.00 and R 5.02
It shifts 1c, 2c, 3c, 3L, 4L . C = converter, L = locked clutch
Thank you for that @tobyS . I listened to my truck shifting in my sound recording and I thought I heard the 4th gear re-locking.
Here's a sound recording of my truck starting at an intersection and running through the gears:
You can clearly hear the shift into 3rd gear, then 3rd gear locking up. I think it sounds like the transmission does the same thing for 4th, unlocking into 4th then locking into 4th, despite everything I've read saying otherwise.
tobyS
839
IN
I have to return this fold out schematic of the 1545. I have it in PDF emailed to me but don't know how attach it with my I pad. Here is an overall shot and one of each end of the schematic.
HDN
5,341
That's in the service manual. I just found the PDF, which I'll post later when I get on that computer.
46
17
Chester , VA
I bought two A3's, one to hold and one to sell, and want to follow up on this (Allison 1545) subject. One of the A3's was purchased with a known tranny problem and I'll share what I have learned.
The truck that I purchased had a used tranny put into it and it does the same thing, fourth and reverse. The former owner's gamble with used did not pay off. I purchased the truck with a non working tranny in it and the original transmission was in a tote box in the bed, entirely disassembled. I ran across this thread and wish the link to the specifications was active...it's not...but I'll add what I have learned.
The military M35A3 was the only one to use the locking torque converter on the 545 series transmission. They added a 1 in front of it but that is not the same as an Allison 1000 series, an entirely different animal. Unlike the 545, there were only 5,600 A3's made so the availability of the 1545 transmission is extremely limited. It causes fear of this series...and rightly so.
I had not received the torque converter with the rest of the tranny in the box, I contacted the former owner. He located what he thought was the original torque converter. Because of the very good condition of all the gears and bearings on the original 1545 (in the box), I decided to rebuild (using an Allison factory trained technician for the tranny rebuild).
The Allison AT 1545 and the 545 share most components except the locking torque converter and valve body. The hub on the locking converter is larger however, so the non-locking and locking torque converter are NOT interchangeable. You cannot simply put a locking torque converter on a 545 and likewise, cannot put a 545 non-locking converter on a 1545 tranny. But a (very common) 545 with a non-locking converter will bolt right into place of the 1545. Unless one is on the highway all the time, this would be my choice if the 1545 is not rebuild-able.
The parts, clutches, steels, pistons in the 545 are the same as the 1545. You can get a gasket or rebuild kit for the 1545 or order the parts for the 545 and get the two larger seals for the 1545 separately. I had purchased the rebuild parts before I got the torque converter and had the entire rebuild completed when the torque converter arrived. Unlike the original tranny...this torque converter showed wear like one with higher miles. A torque converter rebuild shop said no problem until they say the input hub wear.
Looking at the Allison book of replacement hubs for the converter we discovered they were not available. My heart sank and I was considering a sleeve if the interior locking clutch was in good condition. There was no way to tell without splitting it, cutting the weld off.
Because of diesel popularity there has become an aftermarket industry where significant upgrades to torque converters can be had with billet hubs and additional upgraded clutches (going from one to three). That is the weakness of the original 1545 and probably why they were not more widely used. Of course at low speed, a locking torque converter would be entirely un-necessary.
I found two re-builders that were willing to take on the upgrades to my 1545 converter and I have just today sent it to Dacco in Tennessee (a Transtar company). I'll provide more information and cost when mine is returned. I was extremely happy with the quoted cost.
So to conclude, there are valid reasons to fear the automatics put into the A3, with the locking torque converter since there were only about 5600 of them made, but there are reasonable alternatives. For example: the original seals on the fourth piston hydraulic supply wear and won't put good pressure on the clutch pack but new PTFE seals allow about 20% higher locking pressures and don't degrade near as quickly. Likewise the rebuild on the torque converter hub is important because a seal leak can reduce the fourth clutch pressure. It has to be tight. If you rebuild the entire tranny and not the torque converter, you are only doing half the job.
While this is not about specifications of the 1545, I hope my information may help the next guy that is trying to decide if the A3 is a dog or a plum.
I know it has been a long time since you gave this info , but I just want to say thank you very much
to people like me this info is very helpful
  • Like
Reactions: HDN
