MEP-803A Pegs fuel gage all the way down past empty.
jqc99
NC
I like the idea of using a spacer ring at the bottom to prevent it from touching the sides. I want to use the longer one so I'll have to make something similar so it doesn't hang up. Or I need to find one without the external float like the one the AMMPS uses as shown in post 5. Thank you for the help!
Ray70
5,520
West greenwich/RI
Yes, tanks are different. Read posts 20 and 21.
You need an 8" for a 803 but you may need to put a little "spacer" on the bottom to prevent the float from touching the step in the tank.
csheath
198
FL
I removed the strainer basket because it was corroding. I open the fuel cap and look inside. Problem solved. ;)
snider
Marion Va
for the 803 instead of getting the 8" and making a spacer couldn't you get get a 7.5"? the link to the sending units list all different lengths. im having the same issue with my 803..
dav5
182
Mono, Ontario
The spacer isn't to reduce the depth it is to prevent binding on the tank "step"sender.JPGyou can see the step on the right hand side of the photo
FarmingSmallKubota
1,076
Wapakoneta, Ohio
I have used 3 or 4 of the 8.5" senders on the 803's. The float is very close to rubbing on the side of the step down portion of the tank, so I made a plastic ring slightly larger than the float diameter to press onto the very bottom of the rod to prevent the float from touching the side of the tank.
If you use the 5.5" you won't have any interference issues, but your gage reading will be off by probably 1/4 tank.
The SAE bolt pattern is such that you put the wires pointing to the right ( oil filter side of machine ) when looking at the tank to make the hole pattern line up.
Do you have a picture of this plastic ring or a item number of something that you use as the spacer
Ray70
5,520
West greenwich/RI
Unfortunately it was home made. I cut a ring out of 1/8" rigid plastic just slightly larger diameter than the float.
Then drilled the a hole in the center tight enough to press the disc onto the end of the sender, then a little JB weld quick epoxy to secure it to the sender.
Initially I was going to use a rubber disc, but was worried the diesel would deteriorate the rubber over time, so I went with plastic.
