CARNAC's Historical VIN INFO Thread
CARNAC
The Envelope Please.
685
Corpus Christi, TX
Your efforts are very appreciated sir! Will my m109a3 be listed eith the dueces?
Thank you very much in advance.
Ron
No, it should be listed under the M109A3. If I didn't pass that file over, then it must not have been pulled or it must have been accidentally deleted from my hard drive.
NDT
7,081
Camp Wood/LC, TX
The file for the M109A3s is attached in post 63.
CARNAC
685
Corpus Christi, TX
Unless it's a rebuilt A1 frame then on the passenger side. Check one of the old VIN INFO threads, it was better stated and there were photos.
SandBar
Full Time Patriot
763
245
GA/FL
M55 and M62 (can only attach 10 files at a time)
What does the REGNO represent in the M51 PDF? I see the SN is the Identification Number correct?
I think I have a IH M51 turned M51A2, closest serial i can find is 2 digits off in the M51 PDF.
NDT
7,081
Camp Wood/LC, TX
Yes you are correct your truck started life with 6602 gas power in 1952. REGNO is registration number, that is the number that was painted on the hood, yours should be 5161327 i think.
SandBar
Full Time Patriot
763
245
GA/FL
That is amazing news, how did you derive the 5161327 hood number out of curiosity? Still re-reading the PDF's to see if I can find the actual SN. Any way to find out what unit it has been assigned to?
NDT
7,081
Camp Wood/LC, TX
When your serial number is missing, find the closest listing and add the difference in serial numbers to the registration number for the listing you found. Sorry very few unit listings are available. Check your bumpers for numbers and letters and post pictures, usually someone here can decode them.
kendelrio
8,985
Alexandria, La
Great job and great info and much thanks! Quick question due to my ignorance... what is a REGNO number?
Thanks in advance.
kendelrio
8,985
Alexandria, La
Ok, edit... simple Google search returned "Registration Number"... so I'm an idiot....
Question pertaining to truck markings... if the truck were say a USMC instead of Army or other branch, how would the REGNO work into the scheme of things?
Forgive me, I was arty, not motor T. If it isnt pull string go boom, I'm lost...
NDT
7,081
Camp Wood/LC, TX
Good question. Each branch of service has it's own registration number system. USMC seems to always be 6 numbers.
Dieseltech795
Trent Lakes, Ontario
I was wondering if you could help me out. I have an 85 M1008 that I am trying to find a little history on. The bumper numbers are illedgable as they’ve been painted over a couple of times. I’ve tried to remove what I could but I think I went to far with sanding. I would like to return the original markings to the bumpers amd tail gate if I could but it would be nice to know where it has been stationed. I do know it was decommissioned from the EPG and was unit 118 but where it was before that is a mystery.
1GCGD34J5FF421564
NG1T1Q
2320-01-123-2671
Smsfastman24
United States
I was wondering if anyone would be able to confirm and maybe help me find any additional information if possible. I recently just purchased a M35A2 privately and like everyone else, wanted to know its history. I looked in the M35A2 WOW file that was posted, but other than the info in the file is there anything else that can be researched? According to the pdf, its a 1969 and has a UIC of W8FBAA which from my understanding is the Maryland Active Guard Reserve. I also know that its a M35A2 w/o the drop down sides or winch, although the truck does currently have a pto winch on the front. It was rebuilt in 6/90 and I did confirm the tag with the frame stamped code, and they do match.
The Serial Number is 32512956
Registration: NK0D8C
NSN: 2320-00-077-1616
Was bought of a private seller in PA which was purchased from a dealer down in Delaware, currently looking for the company name.
Bumper Markings: MDNC 70 REG & HQ 4
NDT
7,081
Camp Wood/LC, TX
70th Reg (maryland.gov)
