- 806
- 831
- 93
- W.WA
Now, there are several problems with this, as things stand. Feel free to correct me:
1) the winch just isn't powerful enough to pull out deuce
and
2) the way it operates in front of the truck, you'd probably kill yourself if it did - not sure if you can fully use the winch from inside the truck, I suppose you can, but it's still a bit tricky.
So, what do people think of an emergency electric winch? Electric winches often have a long cool down, rated to be used to haul something like 10T or more. And have cab controls. I'm picturing something that can be removed and stored, and only brought out when you actually get stuck.
Is the area where the current winch is located (for those that have one) a suitable place for something like this, or would the structure need to be shored up or another location used? Maybe create attachment points directed to the frame and store the cable to make this connection to the winch?
and
