rcamacho
- 848
- 93
- Bainbridge Island Wa
All 4 doors on my 998 need seals replaced. Looking at OEM vs FMP style the latter look interesting. That said, the material used is likely very inexpensive direct from AMZN/other sources. Curious if anyone has sourced their own adhesive seal and how the results were.
4 Door Seal Door Gasket Weather Stripping Peel & Stick Rubber 3m fits
This is enough material for 4 doors. peel and stick non-OEM door gasket material. E-Z Peasy - applies in minutes. Simply use a razor knife to cut off your old door gasket, then peel and stick your new material.
www.federalmilitaryparts.com
New Door Seals for the M998, OEM vs After Market – HMMWV, Hummer H1 , or Humvee | Gear Report
New Door Seals for the M998 Project supplies: Aftermarket Seals OEM Seals Facebook GroupAdventure by Rodrigo Vicente - https://www.hooksounds.com Where to get Humvee, M35A2, M923 & military vehicle parts: Probably my "go to" for real military parts is eBay: HMMWV parts, M35A2 parts, M923A2 parts...
gear-report.com
