- 1,026
- 1,476
- Wilson County, Texas
After talking with someone via PM a bit, I tried to remove the line from the controller under the dashboard when the wheel valves were stuck open & check for some leaking air that maybe was getting past the valves inside... nothing. Passenger side wheel valves stick open still.
I made a fitting to connect the line going to the wheels directly to my compressor hose. The passenger side wheel valves stay open doing it that way as well.
Strangely but not surprising, the rear quick release valve stopped leaking when filling.
I replaced the front quick release valve just because I had one & wasn't sure the front one was good. Same results.
I still think I am having some sort of air pressure keeping those valves open in the line. The only thing I have no done was rebuild the drivers side wheel valves. Going to try that tomorrow. Not sure what else to do.
