- 300
- 391
- 63
- Geographical Center of Virginia
I have an issue where my MEP-005 will not start.
Backstory: Generator ran fine up until around 3 weeks ago when I accidentally ran it out of fuel. Since then after refilling the tank with fuel, the generator will not start. I am getting fuel to the injectors and smoke from the exhaust, but the engine will not start.
Here is what I have checked/performed (after refilling with diesel):
Day tank is full and fuel pumps are ticking like they should.
Main tank is mostly full of diesel
Checked and cleaned the return line check valve at the top of the IP, it was already clean and working right.
I've tried cracking injectors and return lines with no success other than diesel coming out.
Throttle is pulled all the way out.
Engine will try to kick with starting fluid but will not run.
All fault lights are working and none illuminate when cranking, and only the low oil pressure illuminates before and after (obviously because the engine isn't on)
Batteries are fully charged and when I am cranking it is slaved to my HMMWV.
I really need this generator working on Sunday. I have a spare mep-005 that I may have to mount in it's place if I can not get this one to work.
Thanks in advance
Thanks in advance
