LMTV help with hood-cab release
Third From Texas
6,498
Corpus Christi Texas
Where exactly is the leak?
Typically, it's at the truck-side (not cab) and you can see it misting out.
Here's the kit if that is where the leak is:
To raise you cab, fill the lower (manual) reservoir first then the upper. Place a towel over the source of the leak (kiddy pool under the truck if your one of those environmentalist). Cab should raise, repeat as needed.
raxter111
Slocomb,Al
Thank you, where is that lower resivoir that your talking about? near the manual pump? and the upper is the treadle pump?
Ronmar
7,446
Port angeles wa
Yep, you need hydraulic pressure to release the cab latch As it is “t”d off of the lift feed-line to the cab cylinder. what happens is the o-ring seal in the cab latch piston lets go and all the pressure escapes there and the latch won’t open. So you need to ID where the leak is.
If the cylinder is the issue, you can disconnect the line and cap it, then the latch cylinder unscrews with a large socket. Then you can pull/release the latch mechanism by hand and pump the cab up to get it out of the way While you overhaul the latch piston...
ckouba
1,724
Oregon
Or I've heard you can unbolt the catch from the cab as well. Might not help with building pressure in the lift cylinder though.
TomTime
1,664
MD.
Just went though the same problem your having now.
So, how did you do? Get it working?
