- 6,426
- 4,983
- Ft. Lauderdale, Florida
no workie, and one momement after I posted no workie it works
Ain't puters fun?
Ok, so this step won't start the vehicle but will aid in troubleshooting. Got it.The STE-ICE connector is under the large round cover to the left of the shifter.
With the ignition switch off, by momentarily shorting pins (S) and (T) together it will spin up the starter if it's good but the truck won't start. This completely bypasses the control box so if the starter spins your problem is somewhere between the iginition switch and the starter solenoid.
It won't start the motor if the start switch is OFF.Ok, so this step won't start the vehicle but will aid in troubleshooting. Got it.
So... You're saying once turned ON it will start the truck? So, to be clear:It won't start the motor if the start switch is OFF.
Just an FYI...All automatic transmission vehicles have a "neutral start" switch. The difference between the three and four speed shifters is that there is a second "pad" that closes the neutral start switch in the Park position just like it does in the neutral position.I do not start the truck in neutral. I have the 4l80e 4 speed. I start in park. I do not know if I have a neutral start switch.
No, I have Nothing coming out of the ignition switch when I go to "START" on wire #14A to the neutral start switch.
Thank you for that clarification.Just an FYI...All automatic transmission vehicles have a "neutral start" switch. The difference between the three and four speed shifters is that there is a second "pad" that closes the neutral start switch in the Park position just like it does in the neutral position.
View attachment 835271View attachment 835271
you can bypass the NSS, just run run a jumper between the two leads after unplugging them from the NSS.I have replaced the ignition start switch and now have voltage coming out of 14A when I place the switch in the run position but still no start. Now to examine and/or replace the neutral start switch. Hopefully that's the issue.
