What have you done to your FMTV or LMTV today
BERZERKER888
892
Daytona, FL
Definitely good to know.
the greatest obstacle I faced, after locating a retran, (I can't speak highly enough of DaMara Hansen at MTP Drivetrain) was finding a competent installer. As mentioned earlier, Orlando Allison said "if it has an Allison , we can fix it"...they gave me an $1100 shellacking in transport costs when , after one week, they inturn said "nope"... so Orlando Allison is dead to me and won't be getting a glowing Google Review....
Time will tell if Daytona CAT/RingPower will be the go to guys/gals for big-time repairs on any SE LMTVs, thus far Kyle 1 , service manager and Kyle 2 , lead mechanics have be super solid with me...should have my truck back by next week..🤞🤞🤞
Awesomeness
1,514
Orlando, FL
Which is crazy, because this stuff isn't rocket science. You unhook some wiring harnesses and driveshafts, unbolt the transmission, and take it out.
BERZERKER888
892
Daytona, FL
its likely a weight thing... as in not having an apparatus that can remove the trans. from below... or to remove the bed so can do it from above..
beg to differ..lol....
Daytona Cat/RingPower had the old tranny out and new tranny installed in 1 day....the lead technician said the greatest challenge was the proper drop angle due to the proximity of the crossmember...but as Awesomeness stated, it's easy as pie as confirmed by Daytona RingPower' s lead mechanic...it's just really heavy as in 1600 lbs..20210825_124020.jpg
BERZERKER888
892
Daytona, FL
figured while the truck was up in the air have them replace the u joints/balance and give the underside components a good lookie loo and address any potential issues..and thankfully the rear main seal was as dry as my 60 year old wife......(too much?)...lol
BERZERKER888
892
Daytona, FL
and since they drained the oil from both the TC/tranny..no additional suspected C6 thrust bearing piece/parts were located... in fact the transmission drain plugs/filters had a nominal amount of "fuzz" on them...in theory it appears the screen filter between the t/c and the scavenger pump on the tranny did its job....buuuut...looking back, I still am at peace with replacing the entire unit as opposed to just any mangled t/c components that may have been damaged when the suspected C6 thrust bearing bid this world adeu'...
BERZERKER888
892
Daytona, FL
I happen to have a huge apparatus, but nothing that can do the things you mentioned
P77.... aside from the military specific transmission transmission jack a "civilian" transmission jack won't cut it...the transmission jack they used is huge necessitating the truck to be raised ....so huge it could lift Rosie O'Donnell after 2 hours at the buffet line..
Awesomeness
1,514
Orlando, FL
Gonna have it repaired and sell it?
BERZERKER888
892
Daytona, FL
interesting that you mentioned that....rebuild costs are contingent upon the extent of internal damage..is the case is cracked or broken (location dependant)..no one will touch it.. in fact Momma Allison in Jacksonville stated they don't buy cores or rebuild MD3070's... MTP will give me a credit of..wait..wait... $400..and they pay for shipping back to Louisiana...unless a SS member needs transmission components ?
Bueller?
Bueller?
and since no metal fragments were found in the transmission drain plug/filters/fluid, it appears the $300 C6 thrust bearing may have been the culprit...
DieselAddict
2,018
Efland, NC
Bueller?
Bueller?
Wish I had my shop built. I'm on a waiting list till sometime next year to get the thing started.
Otherwise I'd be interested in going through it to see how tough it is to rebuild. I've done plenty of old school turbohydromatics. Other than being a lot bigger I can't imagine that is any more challenging.
BERZERKER888
892
Daytona, FL
there is a forum member that did the tranny removal and complete tear down/rebuild with limited Transmission knowledge and heavy use of the TMs...I'll try and find the thread..
BERZERKER888
892
Daytona, FL
here is the thread
