sampson123
- 0
- 0
- TN
Stock filter received today from Memphis Equipment, no o-ring to seal for external filter housing. Can I proceed or do i need to obtain a new o-ring? 1986 vintage M925A2
.The oil drain plug is pretty large in diameter any clever tricks for catching the flow of oil without a oil slick?
Excellent idea. What filter base works best? Someone said the baldwin works without any bs. I could make one if I had one to copy.Do yourself a favor and convert to spin on also.
Do you know which fumoto drain plug fits the 250 cummins?Use a funnel and hose to direct it to your 5 gal bucket or container & consider buying a fumoto drain plug to replace OE
Ditto on converting to a spin on and you can get much better media for filtering as the spin on come in extended drain interval and HD.
Buy Fumoto® Valve Online | Replace Oil Drain Plug
By simply replacing your stock oil drain plug, you can drain your engine oil without tools or mess. Trusted by over 10 million satisfied customers, the original Fumoto Engine Oil Drain Valve continues to offer individuals, truck owners, marine engine mechanics, and industrial engine maintenance...www.fumotousa.com
