Need y'alls advice/knowledge/expertise/opinions. Gotta pick up an M129 and get it from WI to MI. Have two different scenarios, being that the 5 ton tractor I was planning to borrow/use is suddenly out of commission. Neither of which are ideal, to be sure but here they are:
1 - Take the bed off my deuce and put on the 5th wheel that I picked up and convert it into a tractor. The M45 was one of the two deuce tractors (that I'm aware of) that used the same frame (longer of the 2) as the M35a2. If I take the bed off, remove the bumpers (and possibly the pintle hook), that gives me 18" of clearence from the back of the truck to the landing gear, ASSUMING that the hitch placement puts the kingpin in the center of the two rear axles on which I run singled out 11.00s. My thought is to extend the air/electrical by extension hoses from the rear glad hands hook ups and longer intervehicular cable, keeping everything out of the way of the trailer articulation via zip ties, etc.
here are my questions on this method:
- is 18" of clearence from the back of the trailer to the landing gear enough?
- the 5th wheel I have is fairly tall (I know NOTHING about various different military or even civillian 5th wheels) and, more importantly, the space between the frame brackets is only 33.5" and both the deuce and m105 (next scenario) trailer frames are 34" wide (see pics). Here's the question - to get that to "fit" on the deuce, I would have to make some brackets out of 3" or even 3.5" angle Iron and bolt them down on the top of the frame rails? This, of course would effectively raise the whole hitch up that much. I have seen another member do this on an M200 generator trailer (rest in peace Microjeep) converter dolly build but, to my knowledge, that was just for moving his trailer around on his property, not highway use. Your thoughts and opinions?
- any perceivable issues with extending the air lines with gladhand to gladhand extension hoses, of course making sure that nothing is kinked, impinged, or tightly bent? I am aware that the lack of tractor protection valve and other normal tractor/trailer "plumbing" makes this less than ideal - this is just to get the thing home.
Scenario 2 - I have an m105 trailer with no box that could be turned into a converter dolly, using the mounting bracket method mentioned above. I would put dually 11.00s on it as well. Now, I know it's a 1.5 ton trailer and, if military precedent applies, that is OFFROAD capacity making it 3 ton ONROAD capacity (correct me if I'm wrong). Now, sice I also know next to nothing about the 105 trailers as I only picked this one up late Fri night (tried to find an m200 generator trailer), I had noticed a second set of springs (see pic) bolted on top of the main set. Being that there are "stops" on the trailer, I was wondering if that is stock or if that was an extra "add-on" at some point. Now, I know that a "tractor" would be better than towing with a converter dolly so......
- is the m105 trailer at 1.5 ton enough to build a dolly for the purpose of getting this UNLOADED trailer home? The military dollies (m197 and 19 are 6 and 8 ton respectively but those are for pulling LOADED trailers, I just need it for UNLOADED highway use. BTW, the m129 is 15k dry weight. I do have a CDL and am aware of the issues with multiple articulation points and unloaded trailers
- IF the second set of springs in the pic is NOT stock, would it stand to reason/help if I replaced it with a "beefier" set of springs?
- any other "percieved" issues, other than what is mentioned?
Thank you all in advance for your comments and advice! Btw, YES I have already thought about having it transported but that would be double what I paid - I would only consider this option as an absolute emergency LAST resort.
