- 7,406
- 2,498
- Interlachen Fl.
Civilian trailer use by the Air Force but now my storage trailer. Had the New doors put on but if they would have just painted the edges of the plywood I would not be working on it. Glad I decided to do it now before the plywood started to come apart from the water that gets under the weather stripping and plywood. Replacing the rubber weather striping and coating the plywood edges. Found this Minwax wood hardener and applied three coats of it on the plywood edges. Filled in any small hole with wood putty and two more coats of the Minwax. I will let it dry for the day and start in on the weather stripping manana.
