jplace1011
- 488
- 63
- Santa Ana, CA
My M1009 won’t start, it tries but doesn’t turn over. I replaced the Glow Plug Relay, Glow Plug Card, The Engine Coolant Temperature Sensor (the sensor at the back of the engine drivers side). Months back I also replaced The Engine Coolant Temperature Switch, the sensor that’s at the back of the engine passengers side. *the pic of the Engine Coolant Temperature Sensor is the old one
I’ve cleaned all the connections in the box that holds the glow plug card, I even cleaned the 6 Pin Connection that some of the wires from the glow plug box go into. After I did that, my Seat Belt Buzzer started working again, just a side note.
I removed the glow plug card and stuffed one end of a wire into the metal tongs/pinchers where the card connects and the Thin Blue Wire comes out behind these pinchers. The other end of the wire I grounded and Click the solenoid engaged.
I did the same thing with a wire into the pinchers that have the black wire coming out of the back. I grounded the other end of the wire, but No Click.
All in all it seems like something isn’t being grounded. If I’m correct, the Black Wire (Ground?) runs from the back of the glow plug box into the 6 Pin connector, from there I see the wires go up into/towards the steering column.
I can get it to start if I place one end of a wire onto the Relay (where the Thin Blue Wire rests) and the other end onto a piece of metal inside the engine compartment. This grounds it and I can hear the solenoid click and it will start afterwards.
Am I missing something, is there something else to replace, check or clean, etc.?
I appreciate any help! Thank You!
UPDATE below:
I watched some video I shot while repairing things. I noticed that a wire has a frayed end. This wire runs from the Engine Ground to the Fuse Box, I’m almost sure. I just shot another clip to verify. Maybe this is the cause?!
UPDATE below:
