Is your blasting cabinet that big? If so I am a little jealous. Also please expand on the 35 spline upgrade. I also understand ORD offers outer axle seals. If I ever get back into my front D60 I will clean the inside of the axle and install those. Great work!
No I didn’t get to blast the axle. I’m actually just borrowing my friends Harbor Freight cabinet, so I was able to get all the other parts into it like the hubs and steering knuckles. For the housing I first pressure washed and degreased, then wire wheeled it and finally sanded with 220. Acetone prep and then primered with Rustoleum. I won’t be doing the final paint until we get another warm spell.
The 35 spline upgrade is merely a new stub shaft that is larger, stronger, and has 35 splines on the lockout vice 30. It’s a solid upgrade, but you also have to change the lockouts because the female splines on the lockout have to then match the new 35 spline stub shafts. Yukon makes all the parts I’ll need
I’m not overly concerned with breaking the axle shaft stubs but it is possible under certain circumstances so an upgrade is in order. Assuming the engine can make 300 lb-ft (doesn’t actually make that much) of torque and with a 2.48 first gear ratio, 2.61 4 low ratio, 4.56 differential ratio, that means that theoretically the axle could see roughly 8,854 lb-ft of torque, which is more than the smaller diameter stub is rated for. When you factor in a 37” diameter tire, steering angles, vehicle weight (shock load potential), and some more fudge factor engineering stuff, it is absolutely possible to break these with even the “weak” ‘ol 6.2 naturally aspirated Detroit diesel.
I will not be reinstalling the outer axle seals that were in there from the previous owner. I know they are available, but I’m not a big believer in them for the Dana 60 axle. They are just not necessary in my opinion, and they hold water inside just as well as keeping water out. I find that most proponents of them are using them as a temporary solution to an inner axle seal leak because they don’t want to remove the carrier and replace the inner seals.
Thanks for the questions and have a great weekend!
Stub shaft part number is YAW46100 (need two)
Spicer U-joint part number SPL55-4X (need two)
Yukon 35 spline lockouts YHC70001 (comes as a set)
