cucvrus
- 10,316
- Jonestown Pennsylvania
.I am struggling with the brake system. I do not think I have enough push power to activate the surge brakes. I vacuum bled both sides and changed the brake fluid. It had a yellow/green DOT 5 I flushed out the fluid with purple DOT 5. I cannot push in hard enough to activate the brakes and I would think that would be normal. i would hope they would not lock with just 200lbs of man pushing in on the pintle. Also, I think the breakaway has to go completely forward to fully activate the brake lockup. I may be wrong. Anyone know? I used the Mighty Vac and flushed new fluid back thru both sides. It was able to hold 20-25lbs of vacuum until I closed the bleeder and released the suction. I don't think on the ground I am capable of duplicating the trailer traveling down the road and locking the brakes. I hope not. I think it requires much more forward force then I can put on the pintle ring or brake plunger by hand. I am open for suggestions.
OK. The three piece ground rod. Take the first piece and stick it in the ground, Screw in the second piece. Put the slide hammer on the second piece. Raise it up, and bring it down SHARPLY. The first piece WILL go into the ground. Some. Depends on how hard the ground is and how many rocks you hit. Repeat raising the hammer until the first piece is compleatly in the ground, or you get tired of hammering bent over double, or on your knees. Remove hammer. Screw in third ground rod piece. Put hummer on the third piece and repeat all the above steps. I fell in love with the slide hammer the first time I used it. Beats the heck out of sledge hammers ALL day. And for removing the rods, man, that alone makes having one worth a million bucks. I always had a forth piece, so I could drive the third piece all the way into the ground. Norm is 9 feet deep, if possible.The center hole goes thru the entire pounder. Explain that.
