Ray70
- 5,796
- West greenwich/RI
Crypto Mining eh.? Those solar panels powering you computer fans I presume!
Great thread! Thanks for posting. Will be following.Lol yeah. Mostly GPU mining these days and mostly RTX 3080 and RTX 3090s. In all, the rigs consume about 8,400 Watts 24/7. During the winter I keep them all up in my house as they provide all the heat I need. In the summer, they hang out down in my shop building.
2020 solar production vs. crypto mining consumption (only captures consumption when rigs are in shop building):
2021:
I sold all my GTX 1080Ti rigs back in the fall of 2020. The RTX 3000's are a lot more efficient. In fact, from spring to fall, my 50 kW solar array produces more power that the rigs and house consume, combined. So during those months, I build up a kWh bank on my account with the POCO that I then eat into during the dark winter months. I have a net metering agreement with the POCO.
So back to MEP 802A #1. All the fastening hardware completed their soaking in the Evapo-Rust and came out looking great:
Currently soaking the water pump plate and misc other adds and ends along with one side of the injection pumps that had a lot of rust on them:
I plan to plow out the pumps with air once done and put them back in the kerosene.
Got the rest of my washers, seals and o-rings sorted out:
That's it for today.
Trust me, I have no plans to ever leave this place!You got yourself a real fine corner of the world right there, pclausen!
Is that a henhouse there on the back of your shed?
Unit | Acquire Date | Build Date | Hours | Cost | Engine ID Tag | Initial Condition | Main Work Completed | New parts | Current Condition | Still to be done |
MEP 802A #1 | 6/2014 | 07 2006 | 3544 | $400 | 44020385DN2WA72 | Water in bores | Block hot tanked, Head rebuild, rings | Injectors, rubber mounts | Putting engine back together | Assemble |
MEP 802A #2 | 6/2014 | 06 2007 | 1355 | $600 | 44006095DN2WA72 | Water in bores | Block hot tanked, Head rebuild, rings | Injectors | In pieces | Assemble |
MEP 802A #3 | 6/2014 | 08 2009 | 2844 | $1,000 | 081028765DB2WA72 | Water in bores | Head rebuild, rings | Injectors | Makes power | Load test |
MEP 802A #4 | 10/2014 | 07 2009 | 3504 | $1,200 | 081028775DN2WA72 | Engine cranks | Cracked rear bell housing | Makes power | Load test | |
MEP 802A #5 | 10/2014 | 08 2008 | 7502 | $800 | 081019635DN2WA72 | Cracked piston | TBD | In pieces | Assemble | |
MEP 803A #1 | 1/2021 | 07 2000 | 5717 | $5,000 | 0006800210DN4WA72 | Makes power | Replaced cracked gauges | Makes power | Fuse Mod, load test |
They were certainly cheaper at auction back in 2014. My 1,200 hour 802A that I picked up in 2014 was $715. Picked it up at Ft Meade. Just needed a new S1 and the petcock soldered back on the radiator. Still using it.Nice update... I almost soiled myself when I saw the hours and price of your Mep-803A #1 !
Was that auction of private party sale?
THAT is a serious henhouse (suitable for sub-letting):
Can I arrange a rent/ Airbnb in the henhouse for two weeks of luxury vacation this summer?The henhouse has power, water and Internet (well Ethernet, but same thing).
Hey, Guyfang, wouldn't you think any good machine shop could mill that up pretty easy and cheap (+/-), if they had all the specs?Very few folks have the gage. I had one and loaned it to a soldier, and you can compleat the sentence.
