CUCV Camo Paint Pattern
Rrent
142
Texas
Pictures are available everywhere of CUCV's and the pattern is no pattern. It is sprayed in the same areas freehand. A proto type model/example just helped to keep the paint somewhat uniform on each CUCV so they were all the same. Originally they were robotically painted. This help keep the scheme uniform on each unit. If done one by one different results are achieved. One guys idea of camo vs another guys is 2 different things 2 different schemes each person would have a different idea of the combination and paint scheme. They adopted the same uniform camo scheme to make all the vehicles look somewhat the same. When new and lined up the were identical paint and the fenders and doors and each part were exactly the same. Kept the uniform camouflage scheme until they were repainted. IMHO I like the look of the original camo scheme with the trim and grille green. I think it shows a well painted vehicle that a lot of attention to detail was used. Many things in automotive look best with the factory set up. And then get mutated as time goes on. it is the original that seems to hold the value and be the real treasure. The survivors as they call them. The res-tiqued not the restored are fast becoming the higher priced in vehicles. Your opinion may vary and that is fine. i just notice lately that people are wanting the patina and mild imperfection to go with the age and add character to the vintage vehicles. Not the same as classic cars. But even some of them are clear coating over rust and dents and minor impofections. the useable and not afraid to drive restorations are going that way.
I know this thread is as old as the hills - but a question, none-the-less. Can I just rattle can the black and brown after a complete green air compressor/paint gun job. If yes - it looks like the camo wasn’t “taped off” except maybe something between the black and brown.
I’ll give it a hard looking at after I spray all green, but think the original style camo give it a little more.
INFChief
1,344
New York
[/QUOTE
Just assume that CARC paint was originally applied. So wear a respirator and keep all paint dust out of eyes and off your skin.
When we painted vehicles there was an Army publication that showed what colors went where and how to place markings and the dimensions the markings should be. We would chalk outline the colors and number each patch 1, 2, 3, and so on. Then the different cam pattern colors were sprayed on - just like “paint by #’s”. If there was a little overspray it wasn’t a big deal.
cucvrus
10,082
Jonestown Pennsylvania
I advise against the chalk lines. I done this one time and I had chalk lines show thru on the edges. If over spray don't matter use a picture and do your best. I painted many things and only did the chalk 1 time with less than favorable results. Not my truck, do as you wish. Have a Great Day.
M813rc
2,954
Near Austin, Texas
As Cucvrus said, chalk shows through the paint.
I have had good luck making small pencil marks at key points of the pattern, don't have any problem with them showing through. I've never tried outlining the whole pattern in pencil, I may have to experiment with that.
A friend did the same trick, but used a magic marker of some sort instead of a pencil- the ink apparently reacted with the paint and bled through to the surface. So you probably shouldn't use those!
Cheers
cucvrus
10,082
Pencil lead on the surface will repel paint. Anything on a top coat is going to interfere with the adhesion and finished results. On a combat vehicle that is still being used tactically it will not matter. On a private owned vehicle I would not like it. I try my best. It is wet on wet. I spray the entire vehicle green and them move on right away to the brown and right after that to the finish of black. I use pictures and a great Wife to point and direct during the camouflage pattern. If it is close and has nice smooth edges it is the look and quality that is needed. Old CARC used to be a PITA and get dry edges everywhere. The best thinner to use was MAK. I used MEK and it dried before it adhered. But with the rattle cans you can do a decent job but same as anything else. 99% of the job is the preparation and without proper preparation you are wasting your time. Over sprayed rubbers, glass and lights are what I see a lot on camouflage paint jobs. Good Luck. Do it right.
INFChief
1,344
New York
Cheers
Not trying to argue; but I will say that I helped paint an entire Mechanized Infantry Battalions vehicles in woodland camo. Not a single chalk line was visible.
cucvrus
10,082
I could not even think of putting chalk on wet paint. But I am not that good at painting, so I guess if you painted a battalion of vehicles with chalk like I said I did it once with less than favorable results. I like the freestyle look. How could it be wrong? It's camouflage. Good Luck.
19,478
It is incredibly OLD FASHIONED but the old overhead projector - something like was used in grade school - is a good way to push the outlines to the truck. The TM that shows you how to paint the shapes with a projector makes the job simple.
YouTube and searching will give you samples. Not especially on military trucks, but you get the idea of how it could be done...
INFChief
1,344
New York
You misunderstood. We traced the camo pattern out in chalk then numbered each pattern 1, 2, or 3. Then we sprayed the chalked pattern with whatever color the number called for. So we were spraying over the chalk.
reloader64
137
Liberty Hill, Texas
Cheers
What's a magic marker?
19,478
Not so magic... Just a marker that is either permanent or removable - generally used on paper. Yeah, they tend to bleed into the paint and stain it permanently. Guessing that it was a permanent (oil based) and repelled the next coat of paint.
Magic Marker is a brand name like Kleenex or Coke
reloader64
137
Liberty Hill, Texas
:LOL: Mostly, I was poking M813rc, 'cause old people say "magic marker!"
frank8003
4,982
Ft. Lauderdale, Florida
Here is something to read about your camouflage.
And maybe, for all that money, one should read the TM's and TB
