- 554
- 1,041
- 93
- Cool, CA
So we have been working on fixing all kinds of leaks in the M1028 and finally pulled the radiator as well. It appeared to have some small leaks near the hose attachment points. Took it to a local radiator shop and they said three days. Well, almost two weeks later they called and said that it was not repairable as it failed during the pressure tests and the inside of the cores was too far gone to repair. Now the big question..........what have you folks been using to replace a radiator in a CUCV. The guy at the shop said you probably won't be able to find a direct replacement since these are super heavy duty and built for the military. Any thoughts, suggestions (and part numbers from the ones you have used to replace if possible). Thanks CUCV experts!
