- 1,680
- 2,168
- Rosamond, CA
If it wasn't bumping, banging, shaking, shimming, rattling while rolling... It would be just another car. Might have something to do with the turn signal label missing, LOLThanks! It's not exactly shimming, which I am familiar with from other cars where the steering moves side to side when it's not held. It is more like a shacking that goes to the whole body, the doors are shacking, the windows, but those are somewhat loose also, and some of the shaking comes thru the steering column but it's not as strong as it looks on the amount of the hood hook movement.
You are 100% right about the hood, it was totally lose when I first got it, the front bolts were not tighten, but I tighten everything sometime ago and I checked it again, it is still very tight. There seems to be two conditions, which may point to multiple combined issues, which may mask eachother in terms of cause vs effect...when the hood moves vs the hooks, it appears to move with the whole truck body, not by itself.
The other case is even at slower speeds when I go over rougher terrain, sometimes it looks like the hooks are moving against the body (I know it's hard to tell, and I use the road as a static point of reference).
Another puzzling thing is that the driver side hook seems to have more movement than the passenger side, but that could also be because I can look straight at its cross section, where the other one is at an angle.
I will take some video, that would explain things better.
Not sure what your saying. Get a hold on the hood by the window washer tank (where one strains to lift it up) and while it's down does in move left to right... right. crack in the fiberglass, crack in the frame, loose hardware... got to love the chase to find it. Good Luck, could this be normal? Going for a ride to see myself.
"E" ticket ride in the HumV, CAMO
