m715mike
- 3,824
- Montgomery, Texas
Lincoln was able to confirm the Off-road ranch. I’ll post more information this evening.Is there a sign up sheet, or how does this work?
Nitrodriver and I come from the east side of Houston. If anyone wants tag along.Now that the real information has been posted. Here is how things have worked in the past. The closer we get to the Rally people will start posting their travel plans. Normally someone near or on that route will chime in and a convoy will get formed. There have been several mini convoys out of the Houston area in the past.
Lincoln normally has a mental checklist of who is coming from where and when. There is always someone that doesn’t show with no contact and always someone who shows up with no prior announcing of that intention. Either way we are pretty casual and welcome all.
TJ, if you come up 105 (and assuming the timing works), then I’ll fall in line with you and Rodney.Nitrodriver and I come from the east side of Houston. If anyone wants tag along.
I was hoping you’d make it!I'm penciled in with my M101A2 camper. Maybe motorcycling the Hill Country before or after.
Thanks to Lincoln, m715mike, and everyone else who worked hard to keep this going!
Well at least you don't have TOO far to go, good luck on the surgery!and I'm JUST now seeing this... partially because I wondered if we were doing a '22 event. I sure hope my knee is up for working the clutch (surgery tomorrow!) and if not, well my co-pilot just might have to drive!
Thank you! it depends if they do my ACL or not... they're scoping, and cartilage repair- but if the ACL looks bad they will do it then.Well at least you don't have TOO far to go, good luck on the surgery!
Hi Rob. You were on my mind the other day. I was thinking that you had already had your surgery and I was hoping you were on the mend.and I'm JUST now seeing this... partially because I wondered if we were doing a '22 event. I sure hope my knee is up for working the clutch (surgery tomorrow!) and if not, well my co-pilot just might have to drive!
Thank you! I did have surgery on my right knee in December... now it's time for the left one!Hi Rob. You were on my mind the other day. I was thinking that you had already had your surgery and I was hoping you were on the mend.
Hope all goes well in surgery tomorrow! I wish you a quick and full recovery in time for the rally!
