- 488
- 367
- 63
- California
As I pulled the tires to rebuild them due to a vibration around 70mph, I decided to also change the geared hub oil.
When I opened the 1” fill plug, a lot of oil started to pour out and ended up being about 30-40% more than the specified 1/2 quart. In the picture the cups are 528ml (0.55 quart) and the fuller cup is already 1/2 quart (473ml):
helical gear is visible thru the fill port
This happened so far on two out of two hubs that I opened and before moving further with the other two, wanted to check with you.
The oil doesn’t look like it has water in it or there is no apparent leak to say that water somehow got inside, however, clearly the facts point that there was a lot more oil inside than 1/2 quart and the question is, how did they put that much in (there is something that appears to be another fill port above the spindle, maybe they used that?)
Do helical gear hubs (which I could not find anything about it in the manuals as new as 2009) require more oil?
