jplace1011
- 489
- 63
- Santa Ana, CA
I will have to pop the hood and take a few pictures of the wiring, in order to answer you questions. If I recall, the wires are both black, but I’ll have to double check.That sensor is a basic resistor with a temp variant...so depending on temp it has a set amount of resistance...I am not sure what it should be so that is the unknown part...does the plug have power or is it a ground type? To test the sensor you need a lead on each of the pins in it...ohms read...any chance the wires are swapped on the new plug?
I’ll get back to you soon.
