Josephml21
- 45
- 18
- PA
As the title says I have an injector pump leaking fuel. I've ripped the whole thing apart, cleaned it and replaced the o-ring on the high pressure side.
I double checked the fuel line and when I put in all back together today I replaced the hose clamp with a new crimp clamp on the low pressure side.
I've thought and tried just about everything I can think of so now I'm here looking for any insight. The leak appears to be coming from somewhere around the base of the IP and the block.
I did notice that when I blew air (from my mouth not compressed air) through the low pressure inlet it was leaking down to the bottom half where the spring and IP pushrod is. I've also noticed that my oil level is rising and it seems thinner leading me to believe that fuel is leaking down via this passage.
When I had the IP apart I looked like the only thing that is stopping fuel from leaking down would be the tight tolerances. Anyone heard of these things eventually wearing out?
