- 5,586
- 2,866
- Metairie/La (N'awlins)
Easy to find. You can use the square or half moon lock pins. Home depot, Lowes, tractor Supply. OE also uses a metal wire rope crimped on both ends on to the pin assembly so it does not get misplaced. Also easy to make with stuff from Home Depot or lowes.Painted, Still need pin for handle. Next will be the spare.
I also had another pin at the ratchet handle hole wire roped as a spare.
I don't remember the sizes off hand but it this style set up:
