Waterhouse
- 122
- 43
- Marianna, fl
So my MEP 803 has always seemed to run fast. The minute I start it, it just roars away. The star wheel adjuster has no effect. I backed off the stop screw so I can adjust the star wheel more. Still no effect. The no load Hz is slightly higher than 60. I don’t suppose that is terrible, but I can’t adjust it down at all. I would like to test it with a serious load, but my AC interrupter won’t cooperate right now. (Another issue)
I have a good working 5 kw also. On it I can dial the Hz up and down with the star wheel easily. I pulled the gear cover to inspect the governor and found a screw that the TM calls a “droop adjust screw”. It has a access plug in the gear cover so you can adjust it from the outside. Of course I didn’t even know it was there until I pulled the cover. Now I’m wondering if that is what was out of adjustment. Have any of you played with that adjustment? It appears to change the leverage of a spring on the governor. The star wheel adjusts the other end of that spring.
I will probably have to put the whole thing back together to see if that is my culpret. Is there anything else I should be looking at in there?
