jplace1011
- 488
- 63
- Santa Ana, CA
@Squibbly @cucvrus
@Keith_J
Today I installed a Pair of Used Bus Bars into my CUCV M1009. I labeled all the wires and Cables as to where they hook up. I think I made a Big Mistake. Video Below.
When I went to hook the batteries back up One cable sparked and the end of that cable fried plus the battery post was on fire for a second or two.
What I did first was connect the Red Cable to the Rear Battery Positive Post. Then When I went to Connect the Other Red Cable to the Negative Battery Post, of the Rear Battery, sparks flew and the post flamed up.
What have I done wrong? I’m thinking something isn’t hooked up properly. I apologize if I’m just being a genuine knuckle head.
Is there a Chart that illustrates how and where all the Cables and Wires should be hooked up to Both Bus Bars?
I do have a handful of other videos showing what’s currently hooked up to what if that helps?
Thank You again and I realize it may just be an obvious mistake. Doh!!
Here’s the Current Cable/Wire Configuration:
Positive Bus Bar
(Left to Right)
Post 1
Red Cable runs to Slave Port Grill/Front of vehicle.
Post 2
Red Cable runs to Starter.
Red Cable runs to Rear Battery Pos. Post.
Post 3
Blue & Orange Cables run to group of cables/wires.
Post 4
Black Cable crimped into Red Wire runs to group of wires.
Orange Wire (fusible link) crimped into Red Wire, runs to group of Wires.
Post 5
Red Cable runs to Neg Post of Front Battery.
Red Cable runs to Small Bus terminal near Master Brake Cylinder.
Red Cable runs back into Cab.
Neg. Bus Terminal
(Left to Right)
Post 1
Black Cable runs to Front Battery Neg Post.
Black Cable runs back into Cab.
Post 2
Small Black Wire runs to group of wires.
Black Cable runs to Slave Port at front Grill area.
Post 3
Black Cable runs to Engine Block.
@Keith_J
Positive Bus Bar
(Left to Right)
Post 1
Post 2
Post 3
Post 4
Post 5
Neg. Bus Terminal
(Left to Right)
Post 1
Post 2
Post 3
