sp00n
- 26
- 28
- Huntsville, AL
2009 M1123 6.5 NA 4L80E in very good running condition. No leaks, none. Zero
The only problem I'm having with it is the power steering feels very much like it has air in the system/low on fluid- however the black lunar lander fluid reservoir typically near the fuel filter on the top of the engine is..just not there. There are no plugged lines, no leaks, and the lines to the steering box are hooked up. Truck definitely has *some* power steering as you can turn the wheel with one finger, but it makes about a quarter turn and then increases resistance then goes back to easy, in a pulsing pattern while you turn the wheel. Exactly like it's got air in it. The pump seems to be present under the 200a alternator, following the hoses did not reveal any reservoir to add/check fluid. Perhaps they updated the system and it's buried somewhere less than obvious? All the 2016+ trucks I have access to at work have the black reservoir right on top.
Like I said, absolutely no leaks or plugged dangling lines. Please advise
