DarkSeas
- 306
- 63
- Leland, N.C.
I've come with pictures, as promised. 2 angles of each alternator:
Can anyone identify which is my passenger side (putting off 24V in series) and driver side (12V )?
Also, pretty sure we put the vacuum pump back facing the right way, can anyone confirm?
Oh and here's the other end of the GP harness that sits under the dash. That clumped bundle of wires in the center is where that harness ends. You know, where the card should probably be:
Some more under-dash carnage...
Somehow all of that kind of works. Works enough to get the motor to start from the key. I'm not really sure what all works on the dash or not. Problem 1 is getting her running again. Problem 2 will be sorting out this mess and making it right. I will probably have to pull everything out and do it from scratch again like I did the motor, that's okay with me.
