WhoMe08721
- 123
- 43
- Bayville/NJ
Hey Guys,
Last year I burn out my starter by cranking the engine to long in the winter month, cause the glow plug where burn out. But this past spring I tested and replaced all the glow plugs and starter. But some times (but not always) when I go to start the engine it will only click like the starter is stuck. When I installed the new started I reinstalled the starter shim and last week I check that the started has a good ground and even used a jumping cable from the battery right to the starter. But still have the clicking so time. Did I buy a bad starter off ebay or do you guys have any other ideas. Also if I have to buy a new starter again any suggestion where to buy a new starter from.
(Video of problem)
(Video of problem)
M998 Starter Clicks
www.youtube.com
