The Modern Day M35
Rob01
Virginia
Cool video, thanks for sharing! I'm curious about the specs on the drivetrain. Top speed? Able to pull itself up hills? Is it loaded with sensors and electronics?
I'm more into the history of the original trucks. But it is interesting to see what new companies are doing with the design.
I can't find the KM250's axle specs.
They say max engine rpm is 2900, and top speed is 95 km/h. That's 59 mph.
M35A2 at 2500 rpm/.79 overdrive/6.72 ratio/9.00-20 top speed is 57.3 mph
Rob01
Virginia
An M35A2 with the 4.90 aftermarket ring/pinion would run 78.6 mph at 2500 with 9.00-20 tires (40.9" height). That's unworkable.
A ratio around 5.90 (65mph @ 2500), in lieu of 6.72 (57.3mph @ 2500), might suffice with that 140 horsepower. Acceptable "startability" must be maintained.
HDN
5,322
Finger Lakes Region, NY
Kia has been building licensed USA 2.5-ton and 5-ton trucks for awhile. I believe they're all still manual transmission but with a modern diesel instead of a multifuel. I'm wondering if they all have split-circuit brakes or full air brakes.
I believe there was chatter in the 5-ton board about using the dog bones and bushings off the Kia trucks as they're an improved design over what was original equipment in the USA.
EDIT: Actually watched the video now - I see they're still air-hydraulic brakes. That music though o_O
davidb56
1,238
Bonners Ferry Idaho
the vid stated 183 hp. I also noticed the transmission shift pattern is the same.
fleetmech
405
Connecticut
I would have to go back and watch the video again but it looked like the brake system used a standard treadle valve. Interesting…
Check out my thread in the hot rodding section "Modern Air Over Hydraulic Brakes". While the thread got a bit overtaken with other peoples different types of project, suffice it to say its totally possible to build a treadle operated air booster to run a split master or even multiple single masters. I linked to a company that builds and sells a kit, or you can build your own from NAPA, eliminating the air pack among other things. Also, take note that there was at least one motorhome company building class A busses well into the 90's with multiple air over hydraulic actuators.
Gypsyman
741
Quincy, FL
I actually did read your thread not too long ago. Very interesting. That's why the treadle valve caught my eye on the newer version.
avAlexangr
35
13
Orenburg, Russia
KM250 Cargo Truck
Home Models KM250 Series KM250 Cargo Truck
KM250 Cargo Truck
The company improved the capabilities of the 2-1/2 ton cargo truck that was developed for the transportation of materials and soldiers. It was improved in order to satisfy the requirements of troops, and to provide high horsepower and mobility.
KM250 Cargo Truck image
KM250 Cargo Truck
Features
  • Engine/power train and frame
    Six-cylinder diesel engine with 180 hp
    Optimized power train with 5 Speed manual transmission and 2 Speed transfer case
  • Utilization for diverse purposes
    Detachable soft-top over cabin, and a water-proof tarpaulin (support-beam) over rear deck
    Folding windshield for increasing versatility on the battlefield
  • Instrument panel
    Simple and highly legible instrument panel
    Tachometer (accumulator), rotation speed gauge, fuel gauge, cooling water thermometer, oil manometer, voltmeter, and air pressure gauge
  • Deck
    Loading capacity: 13㎥ (3,736mm x 2,227mm)
    Loading weight: 5,000kg
    Detachable floor sheets, and water-proof tarpaulin for the deck
  • Differential locking device (NSD)
    This is mounted on the differential on the rear axles for ensuring driving on any surface conditions including damp ground and/or icy and sandy surfaces.
  • Hauling system
    The hauling hook is installed on the rear of vehicle for connecting the trailer to the vehicle (hauling weight on a paved road: 4,500 kg)
    Receptacle for supplying 24-V power
  • Winch (optional)
    Remote control power-driven winch mounted on the front of vehicle
    Maximum hauling power: 4,546 kg or more
avAlexangr
35
13
Orenburg, Russia
KM500 Cargo Truck
Home Models KM500 Series KM500 Cargo Truck
KM500 Cargo Truck
This 5-ton vehicle is for transporting materials and soldiers. The vehicle was developed for military use by adding an engine with higher horsepower,
a reinforced power train, and improving the usage of instruments and switches.
KM500 Cargo Truck image
KM500 Cargo Truck
Features
    Six-cylinder diesel engine with 270 hp
    Detachable soft-top over cabin, and water-proof tarpaulin (support) over rear deck
  • Instrument panel
  • Deck
    Loading capacity: 15.6㎥ (4,267mm x 2,235mm)
    Loading weight: 10,000kg
  • Hauling system
    The hauling hook is installed on the rear of vehicle for connecting the trailer to the vehicle (hauling weight on a paved road: 13,605 kg)
  • Winch (optional)
    Maximum hauling power: 9,070 kg or more
