jplace1011
- 484
- 63
- Santa Ana, CA
My Vehicle: 1985 CUCV M1009
I’m fairly certain the gas tank is the stock/original size (that’s a 25 gallon right?)
My Fuel Gauge has started to occasionally stop working. I checked the fuses, etc. From what I understand it can often be a bad connection at the fuel gauge in the dash end or at the other end, a Bad Sending Unit.
I recently cleaned and rebuilt much of my Dashboard/Instrument Bezel. This included installing a new circuit at the rear of the instrument bezel. I’m hoping the eliminates the Fuel Gauge/Dashboard end in this problem.
If the Fuel Tank Sending Unit has gone bad, it would need replaced. When searching for parts on LMCs website, I found 2 types of sending units: 3 outlets or 4 outlets.
If I’m reading the product description correctly (LMC Part 32-5944), there’s only 1 model that applies, which is a 4 outlet. I may very well be wrong.
I looked under my vehicle at the sending unit. As expected it’s a bit dirty and I’m not entirely sure how many outlets there are. I also started thinking, will I damage anything if I hit that area with a hose/water?
I’ll ask the obvious simple question: is there only one type for my particular vehicle? Or did they come in two types of outlets on my particular vehicle? I also noticed the product description doesn’t mention diesel fuel. Does that at all matter?
Thanks in advance for any input or advice. I currently have the CUCV at the shop and am thinking maybe the Fuel Sending Unit can get replaced while it’s still there.
Gas Tank and Components
Shop from thousands of parts and accessories to help you restore, maintain, and customize your Chevrolet, GMC, Dodge or Ford truck or SUV. Keep 'em on the road with the right part, right price, right now.
www.lmctruck.com
