- 488
- 366
- 63
- California
Ok, so like many here I ended up buying a 2008 REV M1151A1 with 8k miles, initially for parts, but after picking it up, found that it had an IROAN in 2012 and it shows that the air filter was last replaced in 2020 at around 5k miles.
The good news is that I was able to get it started and after changing the oil the engine sounds very buttery, the transmission and steering seem to work very well.
Now the bad news
1. There is some blow-by, it did get reduced a lot after the oil change (I use Shell T6 15W40 synthetic) and after adding the CDR valve), but still visible and it would push the oil fill cap about 1/4” up if I put it upside down.
There is also a little oil in the air filter that looks like it came from the original blow-by.
2. There is exhaust escaping mainly at startup where it connects by the turbo, circled in red in the picture below:
I presume this is an easy fix by tightening the two bolts, which attach the exhaust pipe?
3. Oil leaks at turbo and what appears to be at the valves cover on driver side? I am planning to clean the engine to see exactly where it’s coming from:
How bad is it?
Where should I start?
Now the bad news
How bad is it?
