TND, do you want to explain how to do it? It would be useful for me. Thank you.
I would be interested in hearing how to do this as well. Thanks!
You will need about a 26 inch piece of 1 inch square aluminum, epoxy, at least one 9,10 inch torpedo level with a laser and 2 carpenter's plumb bobs a digital protractor, nothing fancy,and heavy (mason) string , enough wax paper and "shiny" magazine pages (10 sheets each wheel, you can use them one end at a time but is easier to do both ends at a time, you alternate the wax paper and pages for the tires to move on as they are adjusted. And they still take a little "bumping" to arrive at the correct numbers. If the tires set on the floor the side wall will "twist" and throw off the measurement. With the OZ tires you can drop a "string" with the plumb bob from the center of the tire(hangs in the center of the tread blocks) to the floor in front and rear of the tires(front and rear) tape the floor, mark the spot and measure front and back for toe in front and toe out back. The piece of aluminum is cut slightly longer than a rim diameter and two short pieces epoxied on the ends so as to set just inside the edge of the rim. If you have the MT tires (I have one of each) the aluminum should be cut about the diameter of the tire and used to drop your string and plumb bob to the floor for your toe measurement. This needs to be measured carefully , epoxy your rim tabs and then cut the ends to equal lengths. Does not have to be exactly the tire diameter but equal from the edge of the rim on both ends. Place the aluminum bar against the wheel straight up and down, place the protractor against it and MAGIC you have the camber.
Now the fun part..... Adjust the rear toe out per spec. Place the aluminum bar parallel to the floor on the face of either rear tire, use the laser level to shoot a beam to the front tire... measure at the center of the front wheel where the beam strikes, do the same on the other side. If they are the same at this point go buy a lottery ticket. They probably will not be,. The idea is to move the toe on both sides left or right as to have the laser measurement equal at the front hub. This "squares" the back to the front. Keep in mind the backs toe "out" , the beam spreads out back to front. Equal distance on each side, toe out to spec and you got it.
You can skip the wax paper if you want to role the truck fore and aft to relax the tires but I work alone on this and the paper is easier for me. Extra hands for the laser and tape come in handy small children LOVE this stuff!
When my tech guy comes buy I'll shoot some pics of my stuff, IT'S SIMPLE just stop and think about it.
Any questions shoot me a DM and I'll send you a phone number. And caster is taken off the hub inspection plate with the protractor.
