- 3,080
- 4,579
- Olympia/WA
I first read that as 46.25 oz of weights not 46 x 1/4oz weight and thought something was seriously wrong.Pulled the wheel after work, soaped the valve, the bead on both sides, and bubbles appeared in the hole there, whatever that's called. I tried to re-torque the bolts but it didn't change. I popped the small half off and the o-ring looked OK, but replaced it with my spare (ordered five just in case). No bubbles now. I put exactly 35psi in and I'll check it tomorrow to be sure.
The tire guy said he had a lot of trouble with two of the wheels, and he put those two on the rear. This is the weights on that wheel - 46 1/4 oz weights. I'll keep my eyes out for one or two more 12-bolt wheels locally. The other back wheel looks to be the same.
12 oz out of balance is a lot, but still within realistic amounts.
As I said in my recent post, one of mine was 9 1/2 oz out of balance.
Still, yikes.
