Anyone put a lock in their battery boxes?
19,777
Chucky,
I was looking at the battery box, not side board locks. Any thoughts?
I have a very technical version of a Battery Box Lock in the picture below.
Chain wraps around the frame.
Loop at the air tank drains.
I could upgrade it with some green paint.
Ohhhh and I almost forgot - the locking device design is Patent Pending
chucky
18,965
TN .
Oh i misunderstood thats easy get a big piece of threadall and drill a hole in the center of the battery box bottom put the threadall in the hole put a nut under the box and one on the inside to stand the rod straight up then put a nut and washer near the top of the rod then drill a hole in the lid in the center then slide the lid over the rod put the 2 ears in the back into the slot then lower the lid down over the rod and rest on the washer /nut drill a hole thru the end of the threadall to where you can put a padlock thru the hole so you cant get the lid off
coachgeo
3,463
North of Cincy OH
could do this design with strap metal with numerous hinges and locks to bottom plate below tanks.. aka a giant pad lock hasp similar to this
