- 4,173
- 3,053
- Near Austin, Texas
Back in November when I went to look at my Mighty Mite, I also ended up buying an M715 from the same chap.
It is a significantly modified truck, and had a known bad 350 V8 in it. That said, it also looked a lot like one I had seen pictures of and admired for many years (picture 1 attached), so I agreed to give it a new home.
This will surprise some who look upon me as something of a purist, as I prefer military vehicles in their stock service guise, rather than modified (except perhaps for safety features), but I'll admit I've had shocking ideas lurking in my head for years on what an ideal M715 could be.
The Marines kept the M715 in service in limited numbers well into the 1980s, so I saw quite a few of them. These sported 11.00-16 tires rather than the stock 9.00-16s, mostly because the 11.00s gave better performance in beach sand, which Marines tend to transit rather regularly. I liked the way they looked.
Having seen the M715s/M725 that Barrman and Sermis had modified with 6.2 diesel engines, I was duly impressed, as I have long been suspicious of the stock Tornado engine. Barrman said the 6.2 was pretty much an ideal engine for these trucks. I also think that most vehicles could benefit from being diesel powered. Since the Tornado from this M715 was already gone, and the 350 was almost assuredly toast, a 6.2 was a logical choice to stick in there, and I just happened to have one sitting around waiting for a home.
So.... how do I justify in my little brain the significant modification of a military vehicle?
The answer is to indulge in a little "Whifery" (What If...).
What if the M715-series had not been cancelled early and gone the full anticipated production run of something like 70-80.000, and what if it had then served (as it should have) into the 1990s alongside the Humvee? Would it not make sense that it would have had upgrades along the way? And would it not make sense that upgrades could include sharing common items with the Humvee/CUCV vehicles?
Since the military did away with all gasoline powered tactical vehicles during that time, surviving M715s would have had to get a diesel of some sort anyway, makes sense they'd use the common 6.2.
That would all make the concept of an M715 with 6.2 engine and Humvee tires quite logical and feasible. Since this is Whifery anyway, I will presume that there was a less modified M715A1 in there somewhere *, and I'll call mine an M715A2.
So, along we go with this rework. There will be some modifications of the M715 from 'as bought' as shown below to remove some of the unwanted civilian embuggerations.
If anyone is an actual purist, please look away now lest you be mightily offended!
Cheers
* PS - I had a little thought niggling in my mind for a while reference the M715A1 designation and why I didn't want to use it, and finally remembered that designation was used for a Kaiser Jeep proposal, that was not accepted, for production series modification. This included changes to the engine, and larger tires (10.00x16) for better clearance and off road mobility. I have a PDF copy of that proposal in my files.
Pictures -
1 the truck that led me to impure thoughts about M715s
2 and 3 are the one I bought, complete with troop seats and tools
4 and 5 are the Gladiator trucks the M715 was based on, which also explain where those pie pans in my front panel came from.
Cheers
Pictures -
