Front brush guard ideas
serpico760
1,894
San Diego, CA
I've been tinkering with more ideas for a front brush guard what do you think? Some Baja Designs lights also.
lower edge mounted to where the cab tilt hinge mounts. Would do a custom grill.
Ronmar
7,980
Port angeles wa
I don’t know that I would attach it right up under the window, but to the tilt mounts sounds like a good plan. I am working out something similar To tie into my roof fairing/storage.
serpico760
1,894
San Diego, CA
I was rethinking that idea. There are threaded holes there that the European versions attach hand holds to, but then I was thinking in case of hitting an obstacle such as a tree limb the force might go to the windshield loop and crack the windshield so I might just go straight over from the bottom mount over to the side by the bottom corners of the windshield at an angle kind of matching the angle of the bumper next to the glad hands.
Ronmar
7,980
Port angeles wa
something also to consider is that there is only about 2-1/2” of space straight ahead from those Allen head cab to pivot mount bolts to the top of the bumper When the cab is tilted.
hike
—realizing each day
874
Texas Hill Country
Broke Overland made several videos for his brush guards, ladder, and roof rack build. Here is the first one:
Note in his second video he gets rid of the rivetnuts and improves the pipe/tube bender—
ramdough
1,730
Austin, Texas
I agree…. Assume that one day you will bump something hard enough to bend your cab. Do you want to pound out a dent or replace a windshield *and* pound out a dent? ! ?
