- 752
- 1,894
- 93
- San Diego, CA
I was rethinking that idea. There are threaded holes there that the European versions attach hand holds to, but then I was thinking in case of hitting an obstacle such as a tree limb the force might go to the windshield loop and crack the windshield so I might just go straight over from the bottom mount over to the side by the bottom corners of the windshield at an angle kind of matching the angle of the bumper next to the glad hands.I don’t know that I would attach it right up under the window, but to the tilt mounts sounds like a good plan. I am working out something similar To tie into my roof fairing/storage.
I agree…. Assume that one day you will bump something hard enough to bend your cab. Do you want to pound out a dent or replace a windshield *and* pound out a dent? ! ?I was rethinking that idea. There are threaded holes there that the European versions attach hand holds to, but then I was thinking in case of hitting an obstacle such as a tree limb the force might go to the windshield loop and crack the windshield so I might just go straight over from the bottom mount over to the side by the bottom corners of the windshield at an angle kind of matching the angle of the bumper next to the glad hands.
Yup seem them all!Broke Overland made several videos for his brush guards, ladder, and roof rack build. Here is the first one:
Note in his second video he gets rid of the rivetnuts and improves the pipe/tube bender—
Sweet, where do they sell these online?What ever sise pipe u decide on its much easier to buy butt weld to make your turns most benders wont make tight bends the dies are too big ! You can get sch 40 or 80 View attachment 908804
Good to know yeah I was planning on mocking something up with cardboard tube or PVC where that wassomething also to consider is that there is only about 2-1/2” of space straight ahead from those Allen head cab to pivot mount bolts to the top of the bumper When the cab is tilted.
