- 3,560
- 3,461
- Brooklyn, NY
Great Jack, but NOT light. Wear your back brace.I bought a Bogert hydraulic jack for my Humvee! Really excited about it because Humvee has caused damage to every jack I have.
Sounds like you have been buying your jacks at Harbor FreightI haven’t tried a scissor jack. I have an aluminum jack that has a rubber pad on it and bolt tears up the rubber pad. I have a different floor jack and the pin that holds the cup to the jack sheared off and it shot out. I think Bogert will be better.
Can’t be any worse than that tire and wheel with the metal run flat in it.Great Jack, but NOT light. Wear your back brace.
Yes and I have had pretty good luck with them. I think they are all made by the same Chinese kids. I got the atv jack for my RoadKings and it works great on my Cobra also. The Humvee is an awkward beast to lift properly.Sounds like you have been buying your jacks at Harbor Freight
FANTASTIC work! May I ask, is this AL, and are you using Pro CAD software or "consumer grade" details, details........ Also tell the guys from ATF I said HI when they drop by.
HahaFANTASTIC work! May I ask, is this AL, and are you using Pro CAD software or "consumer grade" details, details........ Also tell the guys from ATF I said HI when they drop by.
I see you used the lug nut to pull it into place. You have been a member since 2016?Hub stud replacement per TM procedure.
Dude??!!I see you used the lug nut to pull it into place. You have been a member since 2016? You think you could pony up 15 dollars to support the forum?
FYI ,yall..... been lurking here for years, did not realize you could pay with PAYPAL until a while back. I have an aversion to paying with my CC over the net as I think many would. It needs to be pointed out that PAYPAL is accepted.Obviously your heart is in the right place.
Membership should not be weaponized.
This site is meant to be welcoming and helpful.
This is a wonderful site that is potentially free for all. Anything else should be as per member discretion. I’m not comfortable telling others how to spend their valuable $. My feelings are that we don’t walk in their shoes so we shouldn’t have my eyes on their $.
IMHO
I don't think it is necessary or correct to hound people, the owner of this forum gives us the choice, it could simply be mandatory and of course would be worth it.I see you used the lug nut to pull it into place. You have been a member since 2016? You think you could pony up 15 dollars to support the forum?
TM calls for a nut and washers to pull through. Relatively little force required on this one after cooling the stud. Zero thread distortion I can see in this case.I see you used the lug nut to pull it into place. You have been a member since 2016?
Well I guess I'm slipping, I've been here since 2012. Hopefully he doesn't turn me in to the internet police.Dude??!!
