- 6,855
- 680
- Stratford/Connecticut
What COM port is the USB to serial adapter set to? Does it show up properly in windows device manager?I tried the different J1708 and 1939. I think I’ve got a problem with the USB to serial adapter at the moment.
Yep, you should be able to see it come and go in device manager when you plug it in and unplug it, and what com port it is calling itself, so you can select that com port in the app if necessary.What COM port is the USB to serial adapter set to? Does it show up properly in windows device manager?
Yes and don't use no name ones... Tripp Lite Keyspan one is the only one I have used somewhat reliable...USB to serial adapters are notoriously difficult to make work for some applications expecting a hardware serial port.. Best to use a laptop with a built in serial port.
